Archived from groups: microsoft.public.windowsxp.messenger (More info?)
Greetings,
It sounds like compatibility mode may have been engaged on Messenger. To check for this,
click Start, then Run, type "%programfiles%\msn messenger" and click OK.
Right-click "msnmsgr" and click Properties. Then click the Compatibility tab and see if any
options under Display settings have been set. If they have, uncheck them and click OK.
____________________________________________
Jonathan Kay
Microsoft MVP - Windows Messenger/MSN Messenger
Associate Expert
http://www.microsoft.com/windowsxp/expertzone/ Messenger Resources - http://messenger.jonathankay.com All posts unless otherwise specified are (c) 2004 Jonathan Kay.
You *must* contact me for redistribution rights.
"douknowwhoiam?" <graphpix@hotmail.com> wrote in message
news:eFiY%236D8EHA.3368@TK2MSFTNGP10.phx.gbl...
> screen resolution changing 1024x768 to 800x600 when launching MSN Messenger.
> how can i fix this problem?
> after i installed MSN 7 Beta this problem appeared. uninstalled it and
> installed 6.22 again but i still have the same problem.
> O.S. : Windows XP Pro. with SP1
> regards
