I ahve had this problem ever since I did something stupid during a test to see whether my system qualifies for Windows XP. I unplugged a USB camera whilst the system was checking. Now everytime I unplug a device in Windows, it gives me a fatal error message and then it hangs. I think I have done something to my USB drivers. How can I rectify this problem so I can plug and unplug devices without having to restart my computer?
Thank you for your help
PC Spec: AMD Athlon XP 2000+ running at 1.25ghz, ECS K7S5A Motherboard, 768MB SDRAM PC133, Sparkle nVidia Riva TNT2 M64 32MB AGP Graphics Card, Creative Sound Blaster Audigy 2 6.1, Windows Me
Sponsored Links
Hasn't anyone found a cure to this problem yet? Cant i just reinstall my USB drivers? How do I go about fixing these USB Driver Problems?
Reply to marshahu
RightClick on Desktop/properties/desktop/customizedesktop, and make sure that mycomputer is checked. (note it cant be a shortcut to mycomputer, has to be the one i just said above)Right click mycomputer/properties/hardware/devicemanager, scroll to the bottom you should see "Universal Serial Bus Controllers" if you see that under a category named Unknown Device or Other Device that means that you uninstalled your drivers. Just simply re-install them. If not im hoping to tell you that you can un-install then install drivers. If that doesn't work that only other advice that I can give you is reformat
Reply to MyDaDdY
I have tried your advice and the only items under Universal Serial Bus Controllers are:
Sis 7001 PCI to USB Open Host Controller
USB Root Hub
USB Root Hub
These are all reported to be working properly. If I had my Windows Me install CD then couldn't I just delete the aforementioned items, restart the PC and then reinstall them from the Windows Me CD?
Reply to marshahu
no not delete, that just causes more conflicts. all you do is right click and uninstall. when you restart the computer it should say something about new hardare and you install it with the CD you just mentioned, you might also have a seperate CD that came with your computer that is labeled DRIVERS, and you will use that.
Reply to MyDaDdY
I dont have an Uninstall options in my Device Manager. I only have a Remove option. I don't have a separate CD labelled drivers I only have a Windows Me CD?
If I get a separate PCI card with USB ports will I be able to use their drivers for the onboard USB Drivers as well.
Reply to marshahu
Well........? anyone found an answer to the above question yet?
Reply to marshahu
Reply to marshahu
Tom's Hardware > Forum > Applications > Drivers & Firmware > USB Problems
There are 1105 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
