this is my system:
Coolermaster atcs 210 case
enermax 430watt psu
amd athlon xp 1900+
globalwin cak38 fan
kr7a raid mobo
2 x 60gb ibm 60gxp hard drives
1 x seagate 10gb hard drive
2 x 512mb ddr sdram
32mb geforce 2 mx
yamaha 24x10x40x cdrw
matsushita 16x dvd rom
netgear network card
i had setup the computer set up raid install xp pro everything working fine for a day but now it keeps getting stuck on the verifying dmi pool data i have changed options in the bios taken off all the parts then reconnected cleared the cmos but i still cant get past this can you help ?
enermax 430watt psu
amd athlon xp 1900+
globalwin cak38 fan
kr7a raid mobo
2 x 512mb ddr sdram
32mb geforce 2 mx
