G
Guest
Guest
After reading such good early reviews on this board I went ahead and purchased a Soltek SL-75DRV2 mainborad for a new PC I was building:
AMD Athlon XP 1600+
Micron 256MB DDR SDRAM [CAS 2.5]
Primary IDE master:
Quantum AS 40GB
Secondary IDE:
Master: Ricoh 7200
Slave: Samsung SD616 DVD
Video: PixelView GeForce2 MX400 64MB
Case, PSU and cooling:
Auriga 2100 midi tower, Enermax 400W PSU, extra exhaust fan on rear of case, Thermaltake Volcano 7 HSF
CPU temp averaging at about 45C
OS:Windows XP Pro
After 6 weeks of mostly smooth running - I say mostly because there has been the odd time where I've booted up after having moved the PC (from work to home) and the system has shut down after 2-3 seconds. This has come right usually after removing and reseating video card or memory. I can only put this problem down to improper grounding or cards coming loose. Now I have a problem at bootup where the hard drive fails to be detected. I've removed the hard drive and installed on an other PC and I can read data off it fine. I've tried another hard drive as primary IDE master and it has been detected fine at startup. When I put the original drive back in it picked up and booted up fine. A few days later I had the same error again: Primary IDE master failed. When going into setup the drive is not detected at all. When testing the drive in another PC again it is detected fine however when installing again on the SL-75DRV2 it fails to pick up.
Has anyone had similar problems with this board?
AMD Athlon XP 1600+
Primary IDE master:
Quantum AS 40GB
Secondary IDE:
Master: Ricoh 7200
OS:Windows XP Pro
