Strange but True
Just installed new Asus Rampage 3 Gene motherboard with 6GB Kingston triple channel RAM with Intel 980x CPU and an ATI 5970 GPU, all powered by my 1000 Zalman power supply. Installed Windows 7 Professional 64 bit on my Intel 160GB SSD. Everything is flying just fine and then started to plug in my USB devices. My wireless mouse works great in all USB slots in the back. My Kingston 4GB flash disk works fine in all USB slots in the back. My external Seagate HDD works fine in all USB ports in the back of the MOBO. Now comes my CD Library carousels from DACAL. I plug it in and USB host controller can't recognise it. I have 4 carrousel’s so I try each one separately and get the same message. In desperation after an hours worth of fiddling I plug into the front case UBS and works just fine. I then try each USB port separately in the back of the MOBO and find only one port that recognises the DACAL device. Always the same port in the back. So I tried running 32 bit but same problem and same port works. So I plugged in a ISA USB 4 port card and that works just fine.
Now I ask the strange question, why?
The USB ports in the back of the MOBO seem to work fine with all my other USB devices, the only conclusion I can come up with is that not all USB ports are built the same.
Thanks in advance for anyone that cares to shed some light on this mystery.
