Im having major problems with this MB. Here is the setup:
Soyo SY-P4S Dragon Ultra MB
Pentium4 1.6
256MB PC2700 DDR SDRAM
IBM Deskstar 60GXP 60GB
I first tried using a Hard Drive from another computer that already had Win2K on it, during boot up (at the Starting Windows 2K screen) I kept getting a STOP error (cannot access boot drive, or somesuch). So I tried a brand new HD. Loaded the painfully slow Win2K boot disks, created a partition then formatted in NTFS, it got 99% done then gives me an error saying drive may be damaged (yeah right), so I try again connecting the HD to the ATARAID port instead of the regular IDE, same problem. So Im smart and I trick it by using Win98 boot disk to format in Fat32 then run the Win2K boot and convert to NTFS, it worked! But then, during Win2K install I get another STOP error.
Each time I try to reinstall I get another STOP error (IRQ_NOT_LESS_OR_EQUAL or KMODE_EXCEPTION_NOT_HANDLED or somesuch). Does anyone have any ideas? Is this board compatible with Win2K? (I checked Win2K compatibility list but the board is not listed at all). Any help will be greatly appreciated.
+Kyrnel
Pentium4 1.6
+Kyrnel
