Archived from groups: alt.sys.pc-clone.dell (More info?)
I had two drives connected as Cable Select, everything woked OK.
Entering Setup in the BIOS both drives recognized etc.
When I tried to remove the secondary drive, and set the BIOS for one
drive only, it would not enter the BIOS and just hung at "Entering Setup".
Do I need to change the Primary drive setting from Cable Select to
Master for only one drive? OR does the only drive have to be in a
particulr physical position in the rack?
I cannot understand why it it not entering Setup with just one drive?
"EB" <eb@news.net> wrote in message
news:bE%Re.3915$4P5.2852@newsread2.news.pas.earthlink.net...
>I had two drives connected as Cable Select, everything woked OK. Entering
> When I tried to remove the secondary drive, and set the BIOS for one drive
> Do I need to change the Primary drive setting from Cable Select to Master
> for only one drive? OR does the only drive have to be in a particulr
> Thanks.
No need to change the jumpers on the remaining hard disk. "Cable select"
means that the drive knows whether it's primary or secondary by its position
on the cable. The remaining drive should be attached to the end (not the
middle) of the cable feeding into the primary IDE channel.
There is no need to "set the BIOS", whatever that means. The BIOS detects
the drive by itself.
Ted Zieglar
"You can do it if you try."
> Thanks.
Thanks. I will try again.
In addition to the other comments, enter the motherboard BIOS setup and set the
slave device on the primary channel to OFF, instead of AUTO... Ben Myers
>Thanks.
Still don't know what you meant by "set the BIOS", but do heed Ben's post.
Ted Zieglar
"EB" <eb@news.net> wrote in message news:LA4Se.5379$Wd7.4774@newsread1.news.pas.earthlink.net...
