Archived from groups: alt.internet.wireless (More info?)
Hi, I just got my wireless equipment but I can't get any signal on my
laptop. I installed netstumbler and it can't find any access points. I
installed the latest drivers on both and it still won't find any. The
router is revision C3 and the card B3. Any ideas? The router works find
for normal LAN but not WAN.
> Thanks
> Mike Shaffer
By the way, the router is about 2 feet from my laptop.
> Thanks
> Mike Shaffer
Nevermind, I got it to work! =]
>> Thanks
>> Mike Shaffer
Sometimes it would help others if you posted what you did to correct
the problem..
>>>Thanks
>>>Mike Shaffer
> the problem..
With most DLink series 6 routers there is a little trick that works when you
are unable to get it to broadcast a wireless signal.
Using a paperclip quickly tap the rest button three time (do not hold
reset). That tends to "jump start" the wireless broadcast.
"Michael Shaffer" <michaelshaffer@cox.net> wrote in message
news:83kHc.57636$rh.54530@okepread02...
> >>>Thanks
> >>>Mike Shaffer
> > the problem..
> I didn't do anything, it just started working..
"Mike Greene" <revmwgreene@comcast.net> wrote in message
news:Co6dnVoZgdfIXGzdRVn-jg@comcast.com...
you
