G
Guest
Guest
CPU: Intel Pentium 150mhz (socket 7)
Motherboard set to
Voltage: 3.3
Ratio: 2.5x
Bus Clock Frequency: 66.8mhz (this is the lowest setting on the board)
Motherboard: 530BF
The Bus Clock Frequency should be 60mhz, but the board as no jumper configuration for that (from looking at the manual)
I booted up it works, but the CPU reads as a 200mhz, err, I've turned it off just in smoke starts coming from it, any ideas how to get the board to read the CPU right.
Or will this CPU not work with this board?
Motherboard set to
Voltage: 3.3
Ratio: 2.5x
Motherboard: 530BF
