G
Guest
Guest
I have the following setup:
motherboard: dfi ak76-sn amd 761
CPU: Athlon 1.4 GHz
RAM: Micron 256 DDR PC 2100
I am having problems with memory. When I run a diagnostic test, my ram consistently fails in the same spot. Once it is rebooted, it will fail in a different spot but consistently the same until it is booted again. I have returned the ram, and the new sticks do the same thing. I also tried flashing the bios, which did not seem to do anything. Out of desperation, I sent to motherboard back to the company and they tested it saying it has no problems. Can you help me figure out the problem?
thanks
CPU: Athlon 1.4 GHz
thanks
