Need a little help.....
Forum Motherboards & Memory : General Motherboard - Need a little help.....
I am building a new pc for the first time in many years.It is a Soyo dragon p4,with a Box p4 1.6 chip.I sure could use a little help with 2 questions.
1).The Soyo mb manual says "This mb supports non-box cpu's.Heavier cooling fans require a cpu support stand".I am not sure what this means.The mb has a large square plastic frame attached to the mb that appears to be used to attach the fan support bracket,but not sure if its already installed,why a note telling you to install one?..
2).There is a square patch of thermal compound already attached to the underside of the heatsink.Some of it was apparantly scratched off during packaging.I am wondering if I shouldn't remove all of it,and re-apply some more compound myself......
It has been a long time since I built dx/2 486 pc's,and I am somewhat behind the times.Any advice would be very much appreciated.I am ready to start assembly.........Thanks..........:)
If ya don't ask..How ya gonna know.
Sponsored Links
Bump
Reply to vetplus40
1) You've got a boxed p4 with it's own (non-heavier) fan? Why worry?
2) Ideally, you would scrap off the compound and use some artic silver or similar.
Reply to poorboy
Have you already purchased the P4? I recommend you get a Northwood (1.6A) if you can.
<font color=orange>Quarter</font color=orange> <font color=blue>Pounder</font color=blue> <font color=orange>Inside</font color=orange>
Reply to FatBurger
Yes,I have already purchased it.
The "non boxed cpu" statement in the manual still confuses me.The fan that came with the cpu is plenty heavy.I dont guess that I have ever ran across a cpu stand...............Thanks for the replies.....:)
Reply to vetplus40
Why did you choose P4, Should of Chose AMD, save money for the same, or Better performance..
Later, Rob
Once you go AMD, You never Go back!!
Reply to Rob423
For my personal use,I don't think that I would really notice the difference.I don't plan on overclocking,and I have always had exceptional performance,and reliability with Intel.I have nothing against AMD cpu's,and competion will only make them both better,but if everyone only bought AMD,then we would eventually wind up with a one chip maker scenario.......:)
Reply to vetplus40
Agreed, give the guy a break! Intel processors are great too! Yes, they are priced a bit high, but they perform well and are equally stable.
AMD technology + Intel technology = Intel/AMD Pentathlon IV; the <b>ULTIMATE</b> PC processor
Reply to AMD_Man
Maybe it means that the motherboard manufacturer knows that the boxed CPU p4 fans are too heavy ('motherboard supports ((only!?!)) non-boxed fans') And your heatsink won't work well if there are gaps between it and the CPU.
Reply to fishbyer
Yeah, I was thinking the same thing. The guy wasn't asking about which processor to buy.
BTW, this is proof that AMD_MAN while he is BIOSed AMD (like most of us here at THG), he doesn't give highly-biased advice.
See Chamrajnagar? Ya' satisfied now?
EDIT: After reading the CPU section, I take back that AMD_Man is even processor-biased. Just to clarify though, I'm referring to most of us being AMD-biased based on the price/performance winner. So technically, I too am not AMD-biased...I just want the most bang for the buck.<P ID="edit"><FONT SIZE=-1><EM>Edited by Flyboy on 02/19/02 02:18 AM.</EM></FONT></P>
Reply to Flyboy
I just installed a P4, and the one thing that is different is the retail boxed heatsink. Be sure it's seated and square on the cpu when you move the levers over to lock it in place. I had to do it a second time before it was seated correctly. Also, don't use any thermal paste, or you may void the warranty if yours is a retail boxed cpu. Also, be sure to use the square 4 pin 12 volt connector off your power supply if the mobo requires it. Some do and some don't.
Reply to o1die
I just built that exact board/cpu combo. Used everything as is right out of the box. Heat sink that came with the retail box works fine. Thermal compound that came on the heat sink works fine. Whole thing works magnificantly. No mods necessary.
<i>It's always the one thing you never suspected.</i>
Reply to jlanka
Yeah,everything worked.The cpu stand was already installed,that was the confusing part.The heat patch had to be removed,it was partially scratched off during packaging.....:)
Reply to vetplus40
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Need a little help.....
There are 1132 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
