Yes No
Ads
need some help??
Forum Wireless Networking : General Discussion need some help??
Archived from groups: alt.internet.wireless (More info?)
hi,
how can i setup a home network?? (e.g. between a wireless laptop and pc)
i've tried using the network wizard, but i cant get it to work proerly. i
just want to transfer some files from the laptop to the pc.
and share a printer if its possible.
also, do i have go into the connection screen, and install 'file and printer
sharing for micrsoft windows'??
thanx
devin
Reply to Anonymous
On Fri, 09 Jul 2004 16:24:46 GMT, "Devin Panchal"
What/which network wizard? If it's the "home networking" wizard, you
just setup ICS (Internet Connection Sharing) and effectively made a
mess.
>i just want to transfer some files from the laptop to the pc.
I'll assume you're using Windoze XP. You'll be amazed at how much
better help you get when you disclose what you have to work with.
File sharing:
http://www.wown.com/j_helmig/guidshrh.htm
Printer sharing is just right click on the printer icon and select
"Sharing".
Yes. However, it should have been installed by default in Windoze XP.
It should look something like this:
http://www.wown.com/j_helmig/guidcnf2.htm
Try blundering through the diagnostics at:
http://www.wown.com/j_helmig/guidtstc.htm
and see if anything obvious is amis.
The usual problem is that one machine has received a proper IP address
via DHCP and is at 192.168.xxx.xxx, while the other machine hickuped
or something and ended up with a defaulted IP address as
169.254.xxx.xxx. Networking and sharing will work just fine as long
as BOTH machines are in the same block of IP addresses, but not when
they're that different. Lots of other ways to do it wrong, but that's
what I've seen as the most common because twiddling with the settings
does not necessarily convince XP to ask the router DHCP server for a
new IP address.
Incidentally, the shift key on your keyboard appears to be broken.
You really should get that fixed.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
"Devin Panchal" <d.panchal@ntlworld.com> wrote in message
news:iFzHc.1212$bI4.1183@newsfe3-win.ntli.net...
> hi,
printer
> thanx
> devin
Here is a primer on setting up simple Microsoft networking and you will have
to install file and printer sharing.
http://www.homenethelp.com/web/howto/HomeNet-start.asp
AG
Reply to Anonymous
so do u have to change it to a static address?? i thought i needed to have a
dynamic address, so i can share the internet connection.
my pc and laptop is connected to a wireless router. the router is connected
to the internet.
devin
"Jeff Liebermann" <jeffl@comix.santa-cruz.ca.us> wrote in message
news:dhgte0dn5b7a423cujd7c53kr9nteiv9ro@4ax.com...
> mess.
> File sharing:
> "Sharing".
printer
> new IP address.
Reply to Anonymous
On Sat, 10 Jul 2004 11:08:10 GMT, "Devin Panchal"
No, no, no. Thou art confusing the WAN side of the router with the
LAN side. The WAN (wide area network) side is the one that talks to
your ISP. It gets it's WAN side IP address via PPPoE or DHCP from
your ISP. If you can connect to your ISP (see status page in router
setup), the WAN part is working. This is the "routeable" IP address.
Your computah is connected to the LAN (local area network) part of the
router. The LAN side delivers IP addresses to your computah via DHCP.
This is part that I was mumbling about sometimes screwing up. If the
IP address of your computer ends up 169.254.xxx.xxx, it's *NOT*
working.
>to the internet.
>devin
You really should fix the shift key on your keyboard.
Reply to Anonymous
It could be his cazapitor.
(ok, I'm done now)
Barry
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > General Discussion > need some help??
There are 1726 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Dlink dir-600 router problem
By Realbeast, 6 days ago:
In the WiFax router you should turn off the DHCP service and connect its output to the...
Best offers
Top experts
