G
Guest
Guest
hey,
a while back i decided to upgrade my comp, and bought a ks75a motherboard. on it i have an AMD k7 1.2ghz, a voodoo 3 3000 256megs of ram, and using the on board soundcard.
firstly, the quality of the soundcard is terrible, i cant get it to play well at all, mp3's sound terrible, even more so when there is a site loading. this isnt my main problem though.
the system itself seems to reset randomly, in the middle of doing something, the screen will black out, and restart - this is under win 98.
ive looked all over for motherboard bios updates or extra drivers/fixes but cannot find anything. Is this a hardware problem or have i set something up wrong??
id appreciate your input, thanks in advance.
