Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > sound problems with ac3 codec
Forum Windows XP : Windows XP General Discussion - sound problems with ac3 codec
Whenever I play an AVI with the ac3 codec, the sound plays for about 5 minutes and then cuts out, if I restart the movie again at that point, I have sound, then 5 minutes later it cuts out again. his happens through windows media player 9 but all other types of movies play fine.
Any thoughts ?
Gary
<font color=red>AMD 2700 XP<font color=red>
<font color=red>Gecube 9800 pro Extreme<font color=red>
<font color=blue>ASUS A7N8X deluxe<font color=blue>
<font color=blue>1024 meg Dual Channel DDR 3200<font color=blue>
Sponsored Links
Perhaps its your codec try uninstalling it and reinstalling.
Reply to CapNjacK
- 0 +
Maybe a shareware/trial version that allow only 5 minutes of playback..
-Always put the blame on you first, then on the hardware !!!
Reply to pat
Nothing would surprise me
Reply to agcheavin
the issue i have had is this.
playing a DVD it wouldn't default to AC3 however since the AC3 stream was available it would dedicate the AC3 codec as the decoder of it. the issue with this is it wouldn't decode 2 channel streams. so basicly i needed to change the language to AC3
is it the newest AC3 filter from sourceforge??
and what media player are you using. i use Zoomplayer, i think you need to have PowerDVD or winDVD installed (i think) however since its an AVI i don't know if you do.
anyway have a good one and good luck.
Alltaken
<A HREF="http://www.mud-puddle.co.nz" target="_new">http://www.mud-puddle.co.nz</A> its where its all going on, oh and its also all going on HERE <A HREF="http://doug.mud-puddle.co.nz/gallery/" target="_new">http://doug.mud-puddle.co.nz/gallery/</A>
Reply to alltaken
problem solved, I had divx 4.1 installed and installed divx 5.whatever, and it all went away.
Thanks for your help guys.
Gary
Reply to agcheavin
Oh well, I thought it was solved but wasn't...I still have a movie that keeps kicking out the sound every 5 minutes or so. I might wait until i pick up a new SATA drive and then just re install.
Gary
Reply to agcheavin
There are 515 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
