G
Guest
Guest
Have any of you put together a system with the Lian Li Case? I have a Lian Li 68 and it is making me crazy! Whenever I put my PCI cards in, they do not fit right so i can put the screw in the notch. Whenever I try to get a screw in it, it pops out of the slot. It is making me crazy. I cant screw them in at all. They sorta hang, or they pop out of the slot. What to do? It's almost as if the motherboard is too far back or something. I used the little square mounting pieces they give, pushed them in from the back like they show. It seems whenever I push on the cards the motherboard goes back a bit. Those square nuts do not hold it forward, they push back in. Does anyone know what I Mean? HELP! Thanks.
