G
Guest
Guest
Help!! I decided to take the plunge and try to build a PC. Ordered all the parts and put it together last night. It booted up great and I loaded Windows 2000 before going to bed.
Got up this morning and apparently the gremlins had some fun in the middle of the night. Upon boot up it gave me a long beep then shut down, which, according to my MB manual I assumed was a video card issue. I reseated my video card and from that point on, could not get any beeps or video. Nothing but black screen. Disconnected everything non-essential (one item at a time) to try to isolate the problem. The only sound I can consistently get is when the memory chip is removed. Then I get repeated long beeps. I even took the heat sink off the CPU and put some more thermal goop on it.
Any suggestions about what I should do? Do I have a bad processor, or motherboard?
My specs are:
Soyo Dragon Plus! MB
AMD Athlon XP 2000+ chip
PC Power & Cooling Turbo Cool 425 ATX power supply
Lian-Li PC68 case
Thermaltake Volcano 7 Copper Core w/heat sensor
1x 512 DDR (Crucial)
Visiontek Xtasy t9500 GeForce 3
Etc.
THANKS!
My specs are:
Lian-Li PC68 case
Etc.
THANKS!
