Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Wireless connection stopped working
Archived from groups: alt.internet.wireless (More info?)
My wireless connection on Dell Laptop stopped working after about six
months.
It looks like newtwork itself is fine, laptop can "see" the wireless
network, signal strength
is excellent. However the number of TCP/IP packets received is 0 and it
fails to ping any other
computer on the network.
It is likely not a router,another desktop perfectly works with it wireless
and laptop works
when connected via cable. What could it be?
Laptop -Dell, card-Dell TrueMobile, OS-XP Pro 2002
Thanks
Vadim
Sponsored Links
"vp" <vadimp@iname.com> wrote in message
news:NbgIc.21856$JW6.6301694@news4.srv.hcvlny.cv.net...
> months.
> and laptop works
> Thanks
> Vadim
Try re-entering the WEP keys on the laptop.
Ron Bandes, CCNP, CTT+, etc.
Reply to Anonymous
>months.
That's the symptoms of a wrong or missing WEP or WAP key. You'll have
good signal strength, can associate, but nothing moves data.
Microsloth as WPA and wireless updates, which I suspect is the
culprit.
http://support.microsoft.com/defau [...] s%3B815485
Your laptop probably has an Intel Pro 2100 chip which has its own
collection of problems:
http://www.intel.com/support/netwo [...] prd944.htm
There are also a few access points (i.e. Netgear MR814) which had
"issues" with Intel Centrino compatibility and required a firmware
update to fix and issue stupid press releases like this:
http://presslink.dlink.com/pr/?prid=151
>and laptop works
Bad assumption. The Centrino compatibility issue can cause your
laptop to fail, while others continue to work.
Also, I've had spyware trash the internet connection when I tried to
remove the junk. Most often, it trashes all conenctivity (wireless,
ethernet, dialup) but sometimes only mangles one of these. I've found
that:
http://www.snapfiles.com/get/winsockxpfix.html
seems to fix such problems. It probably won't do anything for this
problem, but can't hurt to try it.
>Thanks
>Vadim
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
There are 1050 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 heli0s won the Freshman badge
  • 14:45 trinix won the Sophmore badge
  • 01:00 citywill won the Uniformed badge
  • 01:00 Tameas won the Uniformed badge
  • 01:00 themeanmachine won the Uniformed badge
  • 01:00 taavi won the Uniformed badge
  • 01:00 mikrouwel won the Uniformed badge
  • 01:00 noiz won the Uniformed badge
  • 01:00 herojig won the Uniformed badge
  • 01:00 mrcmark won the Freshman badge
