G
Guest
Guest
I’m planning to put together a new system and I don’t have a lot of cash to spend so I will not be able to replace a part or get something else if I buy something that doesn’t work well for me. I was hoping to hear some feedback (good or bad) on the parts I plan to assemble. If anyone knows of any problems, conflicts, or things I should be aware of I’d appreciate hearing about it. Thanks a lot! Here are the specs:
Motherboard: MSI K7T266 Pro2 RU (Raid) with VIA KT266A chipset
CPU: AMD Athlon XP 1800
RAM: Micron DDR PC2100 512MB
Video card: VisionTek Xtasy GeForce 3 Ti 200 (I already have bought this)
Sound card: Creative Sound Blaster Audigy Platinum
Not sure if I should get the RAID version. I hear that there are sometimes problems with onboard Raid controllers and the PCI bus?
I already have the video card listed above and a standard ATX case with a 300 watt power supply and a 30GB ATA100 Western Digital hard drive. I plan to play games, dabble with some DV video editing, and maybe record some electric guitar. Sound card has Firewire and the MB supports USB 2.0 which I would like to have. I also plan to put Windows XP Professional on it for the O/S. Thanks again!
