Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Can I do this with wireless? pls help
Archived from groups: alt.internet.wireless (More info?)
Hello. There is something I would like to do with a wireless network, but
since i subscribe to the theory that 'anything is possible if i don't know
what i am talking about', i need to know if it is possible and if so
SPECIFICALLY how to do it.
At work I have a WIRED 10/100 base T newtowrk. The partial T1 line comes
in, goes through a small router (a linksys router) then through 2 16port
hubs. Here is what i want to do: Add a Wireless node or hub to the system,
so if I bring in a laptop with an 802.11b card, or my iPAQ 4355, I can get
on the network. HOW DO I DO THIS? Can I just add a wireless hub to the
network?
Also, does anyone know a good link to an article or site explain to me in
very plain language how to set up wireless so that it is password encrypted
and thus not anyone with an 802.11x card can get on it? How do I set up the
WEP,etc. I am only partially a techie, and the instructions I have seen so
far don't seem to make sense. Connecting to the web thru wireless links
seems to be easy, i get on with no trouble, but in my home and with the
wireless system I want to add at work I would like to make sure it is
encrypted or password protected.
THANKS IN ADVANCE. Mark info (at) Kramden (dot.) net
Sponsored Links
>network?
Attaching an Access Point to the existing hub will be sufficient.
This place usually has good tutorials:
http://practicallynetworked.com/ne [...] reless.htm
Reply to Anonymous
- 0 +
Thanks for this...I am finding that 802.11b routers are pretty cheap.(as
little as $20-30 these days) When you say 'access point' can that be a
router or does it have to be some other specific access point? If it is a
router, how can I hook that into my existing network?
thanks again.
mark
"Jerry Park" <NoReply@No.Spam> wrote in message
news:krjIc.606$m44.212@bignews2.bellsouth.net...
know
system,
get
> >network?
encrypted
the
so
Reply to MD
"md" <info@NOSPAMPLEASEkramden.net> wrote in message
news:a1jIc.149027$2o2.7844117@twister.southeast.rr.com...
What? All you need to do is plug a wireless access point into one of the
hub's and that's it. You will have wireless.
system,
> network?
Again a WAP applinace should do it.
encrypted
the
so
If you have a Domain Controller on the network you may have some control on
a wireless intruder in their ability to join and access resources on the
network. I don't think it means that a machine on the network cannot be
attacked.
If there is a DHCP server on the network, then an intruder should be able to
get a DHCP IP or use a static IP to lunch an attack, especially if the
wireless device is within the trusted zone of the network. They could also
use your network to lunch an attack on another network over the Internet.
The best you could do in this situation is change the SSID on a routine
basis and change WEP or WAP on a routine basis to prevent a wireless
intruder from connecting to the wireless setup to launch an attack.
The thing you may want to look at is not having the wireless setup in the
trusted network zone. You could use a wireless router setup doing port
forwarding from the wireless router into the trusted zone with a router to
router VPN connection. An intruder attacks the wireless router sitting
outside of your trusted network zone, the trusted zone is not so easily
attacked.
Duane :)
Reply to Anonymous
> WHOA! You shouldn't be connecting anything to your corporate network
unless
> it's permitted by your company's security policy and you have permission.
> Non-technical people adding a wireless access-point to the corporate
network
> puts the network at significant risk.
I know this and I assume the OP has absolutely no *clue* as to what's
happening here. The OP seems to be the *it* in some small company P2P LAN
that he's about to get *hacked*.
> For security reasons, you should never connect a wireless access point to
a
> hub; only connect APs to switches.
OK, I'll go with that one.
> The SSID is not a security feature. It is simply the name of the network.
> False security is worse than no security.
What else is the OP going to do but rotate the SSID on an hour to hour basis
so that the SSID cannot be cracked and the wireless exploited. :)
the
> Absolutely. There should be a firewall between the wireless LAN and the
> wired LAN.
I agree too. I would do it with a home setup turning the wireless router
into a WAP/wired switch in the trusted zone behind the WG. I do have a
second IP from the ISP and may use it taking the BEFW11S4 and putting it
into the DMZ out of the trusted zone. But in a home setup, I see the 11S4 as
a WAP/wired switch in the TZ as being no worst than being the only appliance
I had at the I had a couple a months ago.
Duane :)
Reply to Anonymous
- 0 +
system,
> network?
What you need to do is to find a cat 5 calbe and link your AP between your
hub and the 10/100 baset interface on your AP. Then every thing will be OK.
The rest is to configure your IEEE 802.11b card correctly. Either get an IP
address by DHCP or manually configured. Just like the cable network does.
You may assume that your AP acts as a wireless hub.
Hope this helps.
encrypted
the
so
Reply to Walker
There are 1315 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
