G
Guest
Guest
Hi all, I have a K7S5A board running an Athlon XP1700. I've had this board since Christmas, running it with 393 MB SDRAM. Decided to upgrade to DDR, so I ordered a 512MB DDR. When I got it, the MB wouldn't register it. I figured it was a bad chip. Ordered a new Samsung 512 DDR, and it won't work either. The machine will not post. I've tried resetting the BIOS. Did research at the ECS site, and tried thier support's suggestion for BIOS settings, nothing works. I've determined that I may need a bigger PSU (I'm running a 300W). The problem is that my Dad has the same board, having the same problem with DDR. He bought a 460W PSU, and it still doesn't work. (We are in separate states, so we can't swap and compare) This seems to be a major issue with these boards, judging by the ECSwebsite, but I can't get any answers from them. I've been happy with the board running on my old SDRAM and never had a problem, but I want it to work with my DDR now. Any suggestions? Thanks.
Current system includes:
2 HDs, one 40G and one 20G
1 CD burner, 1 DVD ROM
1 ATI 32MB video card
300W PSU
Athlon XP1700
NO DDR, or will run with 393MB SDRAM
300W PSU
Athlon XP1700
