I have 2 systems ... both are pentium III. I am trying to take the "best of both" and put it into one system, and then still have a functional 2nd system to pass along to family.
I'm looking for any help/suggestions about which "core" (basically motherboard/case) to keep.
One system was built local -- has Pentium III 450 -- 100 FSB. 233 watt PS.
It uses a DFI board -- px2bl rev. D. I upgraded the cmos last year. It's a slot 1 board and I have a pentium III 600mhz (off yet ANOTHER machine) that I can put in. Probably won't make that much speed difference, but since I have the part -- any reason not to do it?? What would it involve to change the CPU?
The 2nd system is from Dell --a good PC, but I actually like the case (and the higher power supply) on my locally-built PC better.
I don't know what brand mother board Dell uses, but both systems have the 440BX AGP chipset. Honestly, I'm not even sure what that means =) ... but I know they both have it.
The Dell also has a ata 66 controller card (which I suppose I could put in the locally built if I went with that one ....
both boards accept up to 768 100mhz sdram in 3 dimms. I plan to combine what I have from one or the other to fill all 3.
Any thoughts on which system to build around? Any way to test/compare the boards ... see which is "better"?
I don't really plan to upgrade the system with future CPUs, etc ... but I'd like to keep the better of the 2 ... faster? More reliable???
any thoughts? Any other info I'm missing that would make the decision clearer??
thanks!
deb
thanks!
deb
