Archived from groups: microsoft.public.windowsxp.messenger (More info?)
I have used MSN messenger for a long time .... upgrading along the
way. I simply CANNOT get MSN v7 to connect with my setup.
I am on a LAN (laptop) and all is well with v6.2 however when I
download and install v7 I cannot connect to the internet. I completely
uninstall v7 and go back to v6.2 and it connects ...... no problems!
My OS is Win XP Pro (about 6 months old) with the Centrino chip. 512
MB ram.... and yes ... I have the latest updates. I am baffled.
I have tried ALL of the below hints.... no go ... any other
suggestions would be appreciated.
Thanks!!
******* start cut and paste here ***Things I have tried ************
However, here are some suggestions you should check/try if you haven't
already.
1. The date on your computer needs to be set properly -- double click
the clock verify that
the time and date are set.
2. If your password information is not saved, verify that you are
typing it in with the
correct case (uppercase or lowercase).
3. Change your password @
http://memberservicesnet.passport.com/memberservice.srf to
something smaller (under 10-12 characters), then try signing in again.
4. If you use a firewall (like ZoneAlarm, Norton Internet Security
etc. ), it's possible
that Messenger doesn't have the correct rights to access the Internet,
especially since you
upgraded. You may need to re/add Messenger to the allowed list of
programs in your firewall
if this is the case.
5. If you disabled your firewall in the past, it still may be
blocking Messenger -- try
restarting it and see if that helps the situation. You also might try
uninstalling an
installed firewall, to verify that it isn't causing a problem (even if
it is disabled).
6. Clear your IE cache and cookies -- open Internet Explorer, click
the Tools menu, then
Internet Options, then click the Delete Files button, and when that's
complete click the
Delete Cookies button.
7. Check your IE Security settings -- open Internet Explorer, click
Internet Options, then Advanced tab, scroll to the Security section,
and verify that "Check
for server certificate revocation" is unchecked. Also verify that
'Use SSL 2.0' and Use SSL
3.0' is checked, then click OK.
8. Click Start, then Run, and enter the following:
regsvr32 softpub.dll
then click OK
and do the same for the following:
regsvr32 wintrust.dll
regsvr32 initpki.dll
____________________________________________
Jonathan Kay
Microsoft MVP - Windows Messenger/MSN Messenger
Associate Expert
http://www.microsoft.com/windowsxp/expertzone/
Messenger Resources - http://messenger.jonathankay.com
All posts unless otherwise specified are (c) 2005 Jonathan Kay.
You *must* contact me for redistribution rights.
Thanks!!
already.
uninstalling an
it is disabled).
complete click the
then click OK
Jonathan Kay
Associate Expert
