Yes No
Ads
Tom's Hardware > Forum > Computer Brands > Dell > Does this really sound like a CD problem???
Forum Computer Brands : Dell Does this really sound like a CD problem???
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have a new Inspiron 2200.
All is working fine EXCEPT I cannot seem to write to a CD.
My drive is supposed to be CDRW/DVD combo.
The problem is that any CD I put in appears as Read Only, It will not let me
format a new
Rewritable CD and it won't write on CD's I have that were RW formatted on my
Desktop. It keeps saying that the media is READ ONLY.
I called Dell twice and they will be sending me a new drive.
I am VERY hesitant to open the notebook and replace the drive. Is that a
difficult task??
Is there anything else I can try first?
Mel
Reply to Anonymous
"MB_" <mel@prodigy.invalid.net> wrote in
news:1JGVe.53$Q71.6@fe02.lga:
> Is that a difficult task??
Check your user guide because you may find it is meant to be user-
exchangeable. It would be surprising for Dell to expect you to open
up the laptop to fit the replacement.
Reply to Anonymous
Right click on the drive in My Computer. The last tab should be Recording.
Make sure the option to record is checked.
Tom
"MB_" <mel@prodigy.invalid.net> wrote in message
news:1JGVe.53$Q71.6@fe02.lga...
> me format a new
> my Desktop. It keeps saying that the media is READ ONLY.
> difficult task??
> Mel
Reply to Anonymous
> me format a new
> difficult task??
> Mel
What software are you using? Are you using windows XP CD writing capability
or something like Nero (or Sonic or whatever Dell installs on the machine)?
Personally, I found the windows CD native writing to be pretty worthless.
Peter
Reply to Anonymous
Removal and replacement of CD/DVD drives on most Dell notebooks is really pretty
easy. You don't have to open them up at all. The user's guides on the Dell web
site are very clear and informative... Ben Myers
Reply to Anonymous
RSVP with the model of the drive in your notebook. Click the system icon in
Control Panel, then look at the list of devices in device manager. There is
some chance that you may not have gotten a RW drive.
Forget the CD/DVD burning built into XP. Forget rewritable media that can wear
out at any time. If you don't have 3rd party CD burning software such as Sonic,
Nero, or Roxio, download the free CDBurnerXPPro and use it. Buy cheap
write-once blank CDs... Ben Myers
>format a new
>difficult task??
>Mel
Reply to Anonymous
Ben:
I have a SONY CDRW/DVD CRX835E.
It came with SONIC software.
Yes, recording is enabled.
As I said , Dell is sending me a new drive. I just am wondering if the
problem is the hardware.
Maybe it is.
Mel
<ben_myers_spam_me_not @ charter.net (Ben Myers)> wrote in message
news:43275eb0.39063317@nntp.charter.net...
> in
> is
> wear
> Sonic,
>>me
>>format a new
>>my
>>difficult task??
>>Mel
Reply to Anonymous
The Dell OEM version Sonic is SUPPOSED to work with all CDRWs installed on Dell
systems. Just for fun, try CDBurnerXPPro and see if it works. The nice thing
about CDBurnerXPPro, in addition to it being free, is that it is
vendor-agnostic.
So darn many of these burning packages, whether store-bought or OEM, have
hard-coded limitations preventing their use with certain makes or models of
drives. To be more accurate, they generally include a list of supported drives,
and if your drive is not in the list, you are screwed... Ben Myers
On Tue, 13 Sep 2005 19:46:13 -0500, "MZB" <moo@noway.prudigy.net> wrote:
>Ben:
>Maybe it is.
>Mel
>> in
>> is
>> wear
>> Sonic,
>>>me
>>>format a new
>>>my
>>>difficult task??
>>>Mel
Reply to Anonymous
"MZB" <moo@noway.prudigy.net> wrote in message
news:lxJVe.11534$tc7.2265@fe03.lga...
> Ben:
> Maybe it is.
> Mel
It would not be an uncommon failure to lost partial, but not all, function
of the drive.
The new drive should tell you if you have a software or hardware prob.
Stew
Reply to Anonymous
Ben:
I d/l that s-ware.
I can burn files to the CD, but I can't make the CD such that I can save
more files to it.
How do I do such a format with new s-ware??
I checked its help index and there was nothing about formatting.
Mel
news:432778ef.45783426@nntp.charter.net...
> Dell
> thing
> vendor-agnostic.
> of
> drives,
>>Ben:
>>Maybe it is.
>>Mel
>>> icon
>>> in
>>> There
>>> is
>>> can
>>> wear
>>> as
>>> Sonic,
>>>>let
>>>>me
>>>>format a new
>>>>on
>>>>my
>>>>difficult task??
>>>>Mel
Reply to Anonymous
are you using cdrw media or cdr media?
news:Rj3We.14413$tc7.8779@fe03.lga...
> Ben:
> I d/l that s-ware.
> more files to it.
> Mel
>> on Dell
>> thing
>> vendor-agnostic.
>> of
>> drives,
>>>Ben:
>>>Maybe it is.
>>>Mel
>>>> icon
>>>> in
>>>> There
>>>> is
>>>> can
>>>> wear
>>>> as
>>>> Sonic,
>>>>>let
>>>>>me
>>>>>format a new
>>>>>on
>>>>>my
>>>>>a
>>>>>difficult task??
>>>>>Mel
Reply to Anonymous
First, you need to make sure you have CD-RW (rewritable) media. Next, some
software somewhere needs to do the equivalent of a drive format. (Not familiar
with the details 'cause I do not use CD-RW.) After that, you can write to the
CD-RW pretty much the way you could do with an old-time floppy or a ZIP disk.
I'm not sure if CDBurnerXPPro handles CD-RW. But it sounds like you have
verified that the drive is functional as a CD burner. And you can read what was
burned onto the CD-R, right? ... Ben Myers
On Wed, 14 Sep 2005 20:33:45 -0400, "MB_" <mel@prodigy.invalid.net> wrote:
>Ben:
>I d/l that s-ware.
>more files to it.
>Mel
>> Dell
>> thing
>> vendor-agnostic.
>> of
>> drives,
>>>Ben:
>>>Maybe it is.
>>>Mel
>>>> icon
>>>> in
>>>> There
>>>> is
>>>> can
>>>> wear
>>>> as
>>>> Sonic,
>>>>>let
>>>>>me
>>>>>format a new
>>>>>on
>>>>>my
>>>>>difficult task??
>>>>>Mel
Reply to Anonymous
Yes folks I am using rewritable media.I'm starting to suspect that just
maybe it is the drive.
I d/l all SONIC updates. It still says READ ONLY.
Next step: I'll wait for the drive.
I saw some documentation and it looks like it will not be too difficult a
job to replace it (famous last words!)
Mel
"S.Lewis" <stew1960@mail.com> wrote in message
news:s8TVe.1252$%Q1.1075@bignews3.bellsouth.net...
>> Ben:
>> Maybe it is.
>> Mel
> of the drive.
> Stew
Reply to Anonymous
There are 1730 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 7 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
