Archived from groups: alt.cellular.verizon (More info?)
The manual says Voice Dial options are "Key Press/ Flip Open/Disable"
I can get Flip Open to work OK but I want to use Key Press instead.
Which key activates the Voice Dial after you first open the phone? The
manual is not clear on this.
Thank you
Thank you
