Okay I moved my computer into a new case turned it on and nothing. Everything hummed and nothing happened, fans spun but nothing appeared on the screen. After looking through this database I tried everything. Didn't work. So I switched it back to the original case (call me crazy) and just put in the basics and it worked.
What is the problem with the new case (used the same power supply). Where the mobo sits it has 3 little raised things I popped in and several little screws that screws, screw into. So I put my mobo down on them and screw everything in. Now this new case came with these little washers (almost cardboard but harder). Do I need these and is this why I got nothing on my screen?
Messed up problem I know but any ideas would be a start, my old case is a heat machine. The new one has room for my 2 new fans. Thanks in advance.
