Crash/Resets Error Code. Need Help
This has happened a couple of times now. I can't remember what I was doing the other times, but the last time I was playing a game called Horizons. Out of nowhere my computer resets. When XP loads back up I get the error message:
BCCode : 10000050 BCP1 : E5F01DB4 BCP2 : 00000000 BCP3 : BFA20292
BCP4 : 00000002 OSVer : 5_1_2600 SP : 1_0 Product : 256_1
With the files listed below ready to be sent. I've turned off error messaging, so these aren't being sent to Microsoft. Need some advice here. Thanks :)
C:\WINDOWS\Minidump\Mini030304-01.dmp
C:\DOCUME~1\Arcnite\LOCALS~1\Temp\WER1.tmp.dir00\sysdata.xml
Mobo: Epox 8K7A+
CPU: AMD Athlon XP2200+
OS: Windows XP pro SP1
HD: WD 80GB
HD: WD 180GB SE
RAM: 2x512MB DDR 2100
6 answers Last reply
More about crash resets error code help
  1. Now it's resetting and not giving an error code.. anyone? help?
    Mobo: Epox 8K7A+
    HD: WD 80GB
    HD: WD 180GB SE
  2. Having the exact same problem and error code. Will keep you posted on progress. What's your system specification?
    The machine I have the problem on is an AMD Athlon 900MHz, 256MB PC133, Gigabyte GA-7XR, TNT2 Ultra, 80GB Seagate HDD, Win XP Pro SP1.
    Barton 2500+, 512MB Corsair Platinum XMS 3200 CL2, Radeon 9700, WD Raptor 10,000 rpm S-ATA HDD, Asus A7V600, Enermax 460W SilentPlus PSU.
  3. Right, have a look at this:
    <A HREF="http://support.microsoft.com/default.aspx?scid=kb;en-us;820767" target="_new">http://support.microsoft.com/default.aspx?scid=kb;en-us;820767</A>
    Refers to Windows 2000, but might give some clues.
  4. I'm not longer getting the error code, but it's restarting every time I try to play any game and also when I run Norton Antivirus full drive scan.
    Mobo: Epox 8K7A+
    HD: WD 80GB
    HD: WD 180GB SE
  5. memory problem?..... get adaware or another virus program... Don't have anything running when you run the Virus app.... Get Panda Platinum 7 and RUN it.
    Asus A7N8X Deluxe
    80gb Maxtor
    200gb WD 8mb cache..
    Lian-Li PC-60
    LiteOn 52X/LiteOn 811s DVD-RW
    AMD XP2800+
    LeadTek GF4Ti4200 128mb
    Hitachi CML174
    1GB Corsair XMS PC3200
  6. I had a bad stick of RAM. No problems now.
Windows XP
