Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Remote assistance problems requested through MSN Messenger
Forum Windows XP : Windows XP General Discussion - Remote assistance problems requested through MSN Messenger
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
I'm having problems with remote assistance requested from my Mums PC through
MSN Messenger to my PC.
She requests assistance, I accept and then nothing happens - I get a message
saying it is connecting to her computer but it doesn't connect or timeout -
just sits there until I cancel it.
Her setup is Windows XP Pro with SP2. Windows Firewall is turned on, which
has the following exceptions ticked (on):
MSN Messenger 7.0
Remote Assistance
Remote Assistance - Windows Messenger and Voice
Remote Desktop
UPnP Framework
Windows Messenger
Windows Netmeeting
Her PC is behind a DLink DSL504 NAT router with UPnP turned on.
Both PC's have Remote Assistance turned on under the Remote options of
System in control panel.
My PC is the same setup except it is behind a Zyxel Prestige 652-R11 NAT
router, also with UPnP turned on, and with the same Windows Firewall
exceptions as hers. One difference between the two PC's is the version of
Windows Messenger. Her's is 4.7.3001 and mine is 5.1.0639. Our MSN Messenger
versions are both at 7.0.0813.
Remote Assistance always used to work until quite recently. The only thing
thats changed (afaik) is MSN Messenger - we both used to use 6.2 (can't
remember the build). I installed Windows Messenger 5.1 some time again, but
remote assistance has worked with it in the past.
One interesting nugget is that it all works if I use my laptop (also behind
the Xyxel router via a Dlink DWL7000AP access point) to take control
remotely instead of my PC. The laptop is a Dell Inspiron 8100 with XP SP2,
MSN Messenger 7.0.0813 and Windows Messenger 4.7.3001.
So are the different versions of Windows Messenger responsible for this
problem? I need V5 of Windows Messenger as I use this to connect to work
using SIP.
Thanks for any advice.
Mike
Sponsored Links
Forgot to mention, there aren't any other software firewalls in use other
than the built in Windows Firewall, and I'm able to do video conferencing
between my PC and my Mum's, with no audio problems.
"Michael Taylor" <mike@(nospam)mtcs.ltd.uk> wrote in message
news:OjEYJUOfFHA.3904@TK2MSFTNGP14.phx.gbl...
> through MSN Messenger to my PC.
> message saying it is connecting to her computer but it doesn't connect or
> timeout - just sits there until I cancel it.
> MSN Messenger 7.0
> Remote Assistance
> Remote Desktop
> UPnP Framework
> Windows Messenger
> Windows Netmeeting
> Messenger versions are both at 7.0.0813.
> but remote assistance has worked with it in the past.
> behind the Xyxel router via a Dlink DWL7000AP access point) to take
> control remotely instead of my PC. The laptop is a Dell Inspiron 8100 with
> XP SP2, MSN Messenger 7.0.0813 and Windows Messenger 4.7.3001.
> using SIP.
> Mike
Reply to Anonymous
Has anyone any thoughts on whether using a different version of Windows
Messenger will fix my remote assistance problems? Perhaps re-installing?
Mike
news:%23isQzAPfFHA.2424@TK2MSFTNGP09.phx.gbl...
>> which has the following exceptions ticked (on):
>> MSN Messenger 7.0
>> Remote Assistance
>> Remote Desktop
>> UPnP Framework
>> Windows Messenger
>> Windows Netmeeting
>> thing thats changed (afaik) is MSN Messenger - we both used to use 6.2
>> (can't remember the build). I installed Windows Messenger 5.1 some time
>> again, but remote assistance has worked with it in the past.
>> with XP SP2, MSN Messenger 7.0.0813 and Windows Messenger 4.7.3001.
>> using SIP.
>> Mike
Reply to Anonymous
- 0 +
> Mums PC through
> get a message
> or timeout -
> turned on, which
> MSN Messenger 7.0
> Remote Assistance
> Remote Desktop
> UPnP Framework
> Windows Messenger
> Windows Netmeeting
> on.
> options of
> 652-R11 NAT
> Firewall
> version of
> MSN Messenger
> The only thing
> 6.2 (can't
> time again, but
> (also behind
> control
> with XP SP2,
> for this
> connect to work
> using SIP.
> Mike
perhaps this will help.
http://www.windowsforumz.com/modul [...] highlight=
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Messe [...] 51528.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1756413
Reply to Sparda
Thanks Sparda, I checked it out but unfortunately it doesn't fit. I don't
get messages saying 'connection could not be established', just that it's
connecting but then no response after that. My laptop can provide remote
assistance to my Mum's PC, but my main PC can't, yet both my laptop and main
PC are operating behind the same UPnP router. The only difference I can see
is Windows Messenger on my main PC is newer.
Would an uninstall/re-install of Windows Messenger 5.1 help? Is there a
version newer than 5.1.0639? Would it just make matters worse if I
re-installed 5.1?
Thanks for any opinions.
Mike
"Sparda" <UseLinkToEmail@WindowsForumz.com> wrote in message
news:3_1756413_16ddaa376400a048209c1d70a007bdda@windowsforumz.com...
> > Mums PC through
> > get a message
> > or timeout -
> > turned on, which
> > MSN Messenger 7.0
> > Remote Assistance
> > Remote Desktop
> > UPnP Framework
> > Windows Messenger
> > Windows Netmeeting
> > on.
> > options of
> > 652-R11 NAT
> > Firewall
> > version of
> > MSN Messenger
> > The only thing
> > 6.2 (can't
> > time again, but
> > (also behind
> > control
> > with XP SP2,
> > for this
> > connect to work
> > using SIP.
> > Mike
> request
> Topic URL:
Reply to Anonymous
For what it's worth, I re-installed MSN Messenger (now on build 7.0.0816)
and Windows Messenger 5.1 which is build 5.1.0680, and now I can provide
remote assistance fine using my desktop PC. I think probably that
re-installing WM 5.1 probably fixed it, though I don't know if the higher
build over the previous version had anything to do with the problem.
Mike
news:OVQgjpbgFHA.824@TK2MSFTNGP14.phx.gbl...
> main PC are operating behind the same UPnP router. The only difference I
> can see is Windows Messenger on my main PC is newer.
> re-installed 5.1?
> Mike
>> > Mums PC through
>> > get a message
>> > or timeout -
>> > turned on, which
>> > MSN Messenger 7.0
>> > Remote Assistance
>> > Remote Desktop
>> > UPnP Framework
>> > Windows Messenger
>> > Windows Netmeeting
>> > on.
>> > options of
>> > 652-R11 NAT
>> > Firewall
>> > version of
>> > MSN Messenger
>> > The only thing
>> > 6.2 (can't
>> > time again, but
>> > (also behind
>> > control
>> > with XP SP2,
>> > for this
>> > connect to work
>> > using SIP.
>> > Mike
>> request
>> Topic URL:
Reply to Anonymous
I believe the problem you describe may be related to you having Windows
Messenger disabled or uninstalled. It appears that *MSN* Messenger
relies on *Windows* Messenger to manage Remote Assistance invitations.
If, for example, local policy states that Windows Messenger is not
allowed to be run, then Remote Assistance invitations will fail quietly
without issuing any warning.
In order to resolve the issue, one must make sure that Windows
Messenger is installed on their computer and that local policy is set
correctly. More specifically, run gpedit.msc in order to edit local
policy. Then, make sure that under Computer Configuration /
Administrative Templates / Windows Components / Windows Messenger, the
“Do not allow Windows Messenger to be run” policy is not enabled
(either Not Configured or Disabled). Repeat exactly the same procedure
for User Configuration.
Changing this policy has solved the problem for me. :)
Michael Taylor wrote:
> *I'm having problems with remote assistance requested from my Mums PC
> through
> message
> timeout -
> which
> MSN Messenger 7.0
> Remote Assistance
> Remote Desktop
> UPnP Framework
> Windows Messenger
> Windows Netmeeting
> of
> NAT
> version of
> Messenger
> thing
> (can't
> again, but
> behind
> SP2,
> this
> work
> using SIP.
> Mike * :) :) :)
Nir Pe'er
Posted via http://www.mcse.ms
View this thread: http://www.mcse.ms/message1704394.html
Reply to Anonymous
Thanks Nir. I actually got it working a couple of weeks ago (posted about
it).
Windows Messenger was not disabled on either PC. I resolved it by
downloading and installing WM5.1 build 5.1.0680 on my PC to replace build
5.1.0639.
I use Windows Messenger with work colleagues (using SIP over a VPN) and MSN
Messenger with friends and family. I don't know why a re-install of WM made
it work, but it has.
Thanks for your help. Next time I see a problem like this I'll remember to
have a look at these policies.
Regards
Mike
"Nir Pe'er" <Nir.Peer.1st35y@mail.mcse.ms> wrote in message
news:Nir.Peer.1st35y@mail.mcse.ms...
> "Do not allow Windows Messenger to be run" policy is not enabled
>> through
>> message
>> timeout -
>> which
>> MSN Messenger 7.0
>> Remote Assistance
>> Remote Desktop
>> UPnP Framework
>> Windows Messenger
>> Windows Netmeeting
>> of
>> NAT
>> version of
>> Messenger
>> thing
>> (can't
>> again, but
>> behind
>> SP2,
>> this
>> work
>> using SIP.
>> Mike * :) :) :)
> Nir Pe'er
Reply to Anonymous
HELLO, IM HAVING TROUBLE WITH MY MESSENGER, IT SHOWS THAT MY EMAIL IS NOT
VERIFIED ON THE SCREEN TO OTHER PEOPLE. IT TELLS ME TO GO TO MY IN BOX ON MY
EMAIL AND I DID BUT NOTHING WAS THERE. I CANT GET IT TO SIGN ME IN OR VERIFIY
MY EMAIL.. I HAVE TRYED EVERYTHING!!! WHAT DO I DO TO GET SIGNED IN????
THANKS THE DAWG
> MSN Messenger 7.0
> Remote Assistance
> Remote Desktop
> UPnP Framework
> Windows Messenger
> Windows Netmeeting
> using SIP.
> Mike
Reply to Anonymous
There are 979 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 heli0s won the Freshman badge
  • 14:45 trinix won the Sophmore badge
  • 01:00 citywill won the Uniformed badge
  • 01:00 Tameas won the Uniformed badge
  • 01:00 themeanmachine won the Uniformed badge
  • 01:00 taavi won the Uniformed badge
  • 01:00 mikrouwel won the Uniformed badge
  • 01:00 noiz won the Uniformed badge
  • 01:00 herojig won the Uniformed badge
  • 01:00 mrcmark won the Freshman badge
