G
Guest
Guest
Hello,
I have two IDE drive and one SCSI on my K7S5A motherboard with a Athlon XP 1800 and 128mb SDRAM. After getting slow performance from my hard drives on the built in IDE controller I set out to determine the cause of my problems.
I ran three different benchtests on this system. All of these benchmarks show that the hard drives are causing my perfomance problmes as I am getting a sustained data transfer rate of around 6mb per second. I have two drives an Maxtor ATA 100 20 GB drive and an IBM 45GB 75GXP drive.
Both drive pass the manufacturers utility tests and are both showing as UDMA5 within the BIOS. I also have UDMA enabled within windows as well as having write cache enabled. I have both drives on their own cables one on the primary and one on the secondary by themselves set to 16 head master. I beleive that this may be a problem with my IDE controller. (as the drive perform great on my other system with a promise ATA 100 controller) I checked DM to find my driver provider and sure enough I have Microsoft as the driver provider. I have been unable to locate an SIS 735 IDE controller driver anywhere. If anybody knows the location of one please let me know or if you have any other suggestions I would greatly appreciate it.
Thank You,
Thank You,
