Tom's Hardware > Forum > Games General > PC Gaming > Battlefield 2 chunky problem
Forum Games General : PC Gaming - Battlefield 2 chunky problem
I have battlefield 2, but it runs....well not smooth, im so darn sure its my video card (Geforce 6800 128mb), but people keep saying its my RAM. 1 gig DDR 333. But i seriously dont think that is the problem. When i put my other card (radeon X600 256mb) put the settings on low with the view distance to 100%. It ran pretty darn smooth. I took my card (geforce 6800 128mb) put the settings on low, view distance to 100%, but it ran crappy. Would a better video card help this chunkyness?
Sponsored Links
Obviously it would, but that's not the underlying problem. What resolution are you trying to run it at?
Also, what is the rest of your system specs.
BF2 is a major resource hog, but on low settings, 1GB should be enough. If you can, I would still try 2GBs, but that's not always possible.
Reply to bman212121
my specs are AMD Athlon 64 4200+ 2.2ghz
1 gig Patriot
180GIG hardrive.
Geforce 6800 128mb
Im wanting to run at 1024x768
high settings.
Reply to Korbin91
I had the same trouble with my Leadtek 6800 GS 256 Mb. I put all settings to max at 1024 by 768 with 2 x aa and noticed tjhat the harddisk is grinding a lot with the initial play. I decided to put in another 1 Gb of Ram to arrive at a total of 2 Gb and voila! all going smoothly for me.
Tey and borrow a few sticks form your mate or something to try out. I think your card is good for gaming, no need to upgrade as of yet. The disk activity during gameplay ought to telll you a lot, so observe :)
Also, I recently switched to 64 bit windows XP pro and noticed that my BF2 is playing smoother than before as well. not sure well :) the best thing to come with it is that I have an older audigy card in this machine and the new driver provided by Creative seems to give me better sound in gameplay and music as well lol. I will prob put in my xtreme music soon from the other PC and see how it sounds.
Reply to raptor50
- 0 +
I used to run BF2 with my 6600GT 128mb with 1gig of ram with only a little stutter at the beginning of the maps almost maxed out on graphics. I upgraded to 7800GT actually didn't change that, upgraded to 2gigs ram, runs smooth from beginning to end maxed out.
Having only one gig and the fact that it is running 333mhz is not helping. Get the fastest ddr400 you can afford. 2x1gig preferably do not go with 4x512 if you can avoid it.
This game's code has a massive memory leak. The main reason for the stuttering is the game accessing the hard drive page file system.
OCZ has a nice set of 2x1gig Platinum 2.2.3.5. 1T at newegg I think it has a rebate as well.
http://www.newegg.com/Product/Prod [...] 6820227210
3500+ Winchester
MSI K8N Neo Platinum 7100
2x1gig OCZ Platinum EL
BFG 7800 GT OC
Raptor 74
Raptor 36
Ultra 500w PSU
Reply to cisco
There are 1404 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
