Tom's Hardware > Forum > Games General > PC Gaming > Fear Problem - Max res only 1024x768
Forum Games General : PC Gaming - Fear Problem - Max res only 1024x768
I'm having a problem with screen resolutions - the game only gives me 3 choices (640x480, 800x600 & 1024x768) and I know my system can handle 1280x1024 but I can't find a way to set that resolution in the game. :oops: I'm curious if anyone else has this problem or knows how to fix it?
Sponsored Links
What monitor are you using. If your monitors maximum resolution is 1024x768 then you can't go any higher.
Reply to jumpmaster
- 0 +
It's an LD90+ - 1280x1024 19" LCD
Reply to Avman
Have you tried installing the latest patch?
Reply to jumpmaster
- 0 +
yep - even re-installed the game.
Reply to Avman
Do you have the latest monitor drivers?
Reply to rumcooler
- 0 +
Yep -5/05 from Hyundai/Imagequest - All drivers are up to date.
Hardware wise I know what I'm doing - I just can't figure out why the game won't recognize the correct settings.
Reply to Avman
"C:Documents and SettingsAll UsersDocumentsMonolith ProductionsFEARsettings.cfg"
"ScreenWidth" "1280"
"ScreenHeight" "1024"
Try to force it and see if it works.
Reply to rumcooler
- 0 +
Yep - Forcing it works and as long as I don't change any other settings it stays that way. But as soon as I go into the "Display" menu it changes back to 1024x768 and doesn't offer 1280x1024.
Reply to Avman
Sorry don't know what else. I'll do some research! :?
Try this a little more info
http://www.tweakguides.com/FEAR_7.html :D
Reply to rumcooler
The game officially supports only 4:3 aspect ratio displays as stated on the box. 1280 x 1024 is a 5:4 ratio display and the closest you will get to it is 1280 x 960.
Reply to rumcooler
Ahhhhh jealous of you guys, my pc actually takes a crap on it self, and then sets alight when it tries to play FEAR. :(
Reply to jonojace
- 0 +
I know how you feel - A couple of years ago I finally decided that I was sick and tired of slow, so it was time to start investing...thankfully I've been able to support my ever worsening hardware habit. My latest habit is a 7900gt thats now volt modded and running 24/7 at 651/1800 and it can still play games at 700/1800!!! 8O
Reply to Avman
not a fear problem....your problem..
Reply to sandmannight
There are 1076 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
