Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
Greetings --
The Product Key is not on the installation CD at all. That would
be rather like storing one's house key in the front door's lock.
The Windows 25-character Product Key (required to perform the
installation) is stored on the CD packaging on a bright orange sticker
that says "Do not lose this number." If it was an OEM (factory
installed) license, it's stored on a label that the PC manufacturer
affixed to the exterior of the PC case, or on the bottom of a laptop.
To recover a lost Product Key:
If your system still runs, you should be able to use AIDA32
Enterprise from
http://www.aida32.hu/aida32.php to find the Product
Key. (If you have a factory-installed OEM license, and haven't since
reinstalled the OS, the revealed Product Key is probably of the drive
image used at the factory and not _your_ specific Product Key;
therefore, it probably cannot be -- and definitely should not be --
used for a re-installation.)
If it was a retail license and you have proof of purchase:
How to Replace Lost, Broken, or Missing Microsoft Software or Hardware
http://support.microsoft.com/default.aspx?scid=KB;en-us;326246
If it was an OEM license, you should contact whomever sold you the
PC; although very few manufacturers/vendors keep records of the
Product Keys they've sold, it's worth a try before you have to buy a
new license.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on
having both at once. -- RAH
"tjbuilds" <tunji07@aol.com> wrote in message
news:1b34f01c42050$d36bdaf0$a301280a@phx.gbl...
> Hi
> I,m trying to install windows xp on my computer but i
> lost my 25 digit product key. How can i proceed with the
> installation process without it orwhat do u suggest i do.
> Thanks
