G
Guest
Guest
Hi folks,
Strange problem here which hopefully some kind soul can help with since it is driving me MENTAL!
Basically, I decided to make a move from a Celeron 466Mhz to a Duron 1Ghz. I purchased a suitable motherboard (Gigabyte GA-7ZXE SoA VIA KT133A ATX A) and CPU from Dabs. I put it into my case, attaching the fan, RAM (512mb Kingston SDRAM), power cable, floppy drive and power switch.
Upon booting the fan starts up and I am able to access the BIOS screen and play around to my hearts content.
However, upon leaving the BIOS I will experience one of the following problems:
- Display goes blank and nothing happening
- American Megatrends logo in top left and rest of screen
- Memory checked and then hangs on "Wait..."
On the odd occasion that the system gets past this stage and begins to read the floppy it gets as far as "Starting MS-DOS..." and then hangs.
I also tried a Windows ME startup disk which gets as far as the 3 options (Boot with CDROM support etc..) but hangs as soon as I press one.
It is as though the system halts as soon as it tries to execute a program.
My own thoughts as to the source of the problem are:
Insufficient power supply? - I am using the 250w jobby from previous system.
Overheating? - I am using a new dual fan but there is still a fair bit of heat.
Incorrect bus speed? - I've played with jumpers but my understanding of this is below par.
BIOS - I have tried updating this to the newest version to no avail.
Do these symptoms sound familiar to anyone? I would be eternally grateful to anyone who give me an idea why this might be happening (before I start to sob like a baby!).
Many thanks in advance,
Graeme.
Clinical insanity runs in my family.
Graeme.
