Tom's Hardware > Forum > Systems > Dell > M1-ATX Power Supply in Optiplex..
Archived from groups: alt.sys.pc-clone.dell (More info?)
Im trying to put this new power Supply in my Optiplex GX260.
http://www.cartft.com/support/doku [...] manual.pdf
(for use in car) The problem is that it needs a M/B on/off switch. I
think i might have to find to wires from the control panel or? Can
somebody help me here?
Sorry about the spelling. Come from Denmark.
yokeren
Sponsored Links
On Fri, 23 Sep 2005 21:56:53 +0100, yokeren
>http://www.cartft.com/support/doku/manuals/M1-ATX-manual.pdf
If (big IF) I understand you, and the manual, the connection would
perhaps replace the wires that currently go from teh motherboard to
the case On/Off switch. Then the power supplies optional on/off switch
(or the ignition switch?) would be used to power the system.
Maybe an easier way is a 12V to 120 (or 240) inverter? That's what I
use (with my notebook and other equipment) and it is cheap, easy to
hookup and use.
Reply to PeterD
The other way is to use NO connection and turn the computer
on
manually after engine start.
"PeterD" <peter2@hipson.net> wrote in message
news:5p59j1ligm5mdmf77nsah90o0atafodc26@4ax.com...
>>GX260.
>>switch. I
>>or? Can
> connection would
> motherboard to
> on/off switch
> system.
> That's what I
> cheap, easy to
> hookup and use.
Reply to Anonymous
Last I looked these guys had some sort of conversion cables that might help
you.
www.power-on.com
KC
> hookup and use.
Reply to Anonymous
Will that power supply work with the optiplex.... i am looking at the
power supply on my optiplex GX260 and it says 160w output, how is 90w
gonna power the system.
dorgan
Reply to Anonymous
I am just curious if you been able to work this out as i am doing the same thing but with an opus 120 power supply
Reply to Tangerine_Man
There are 829 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
