G
Guest
Guest
A few days ago I have sent the following message to Philips and Soltek.
Until now I didn't get any answer from any of that companies.
So, any info / help is welcome.
Thanks
PS. The onbord sound have been disabled ...
Dear Sirs,
I have bought a Philips Seismic Edge (PSC 705) sound card.
After I have installed the card in the computer, the sound card have NOT been detected by the system.
The sound card does NOT appear in the "PCI Device list..." at the computer start up.
I tested all PCI slots with all BIOS configurations possible.
The MB BIOS version have been updated to the last version available on the Soltek site.
The card is still NOT detected by the system.
I have tested the sound card on other two computers and the sound card is working well.
I have tested other sound cards on my computer and are working well.
I will appreciate any info or advice from you regarding this problem.
Model numbe : Philips Seismic Edge (PSC705)
Computer type, processor speed, and memory available:
- MB - Soltek DRV2 (KT266A, BIOS version 4.1);
- CPU: AMD Athlon 1000 MHz;
- RAM: 256 MB DDR PC2100.
On-screen error information: None !!!
Other hardware connected to your sound card: No other hardware connected to the sound card.
<P ID="edit"><FONT SIZE=-1><EM>Edited by Teodor on 05/11/02 07:39 AM.</EM></FONT></P>
Thanks
Dear Sirs,
