Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > where to buy WIFI antenna extenson cable
Forum Wireless Networking : Wireless General Discussions - where to buy WIFI antenna extenson cable
Archived from groups: alt.internet.wireless (More info?)
I have a Linksys G510 PCI wifi card. Because where the PC is located, I
got very weak signal. I want to put in an extension calbe so I can
position the antanna to get better signals. Any suggestion on where to
get? If there is a store in the S. Calif area, it would be great?
Also, what kind of connection does this wifi card/antenna use?
TIA
Sponsored Links
"NewsReader" <noemail@invalid.invalid> wrote in message
news:2m4t7aFj7opfU1@uni-berlin.de...
>I have a Linksys G510 PCI wifi card. Because where the PC is located, I got
>very weak signal. I want to put in an extension calbe so I can position the
>antanna to get better signals. Any suggestion on where to get? If there is
> TIA
Would also like to buy one in the UK
P
Reply to user
Unless you upgrade the antenna to one with higher gain you/directionality
will get less signal due to losses in the cable + connectors....
Guy
> I got very weak signal. I want to put in an extension calbe so I can
> TIA
Reply to Anonymous
This maybe true but my PC/antenna is about 6" off the floor with a lot
of "stuffs" between it and the AP. If I can place the antenna by my
monitor (~3' from the floor), I was hoping I can get better gain and
offset the cable loss...
> Guy
>>TIA
Reply to Anonymous
You might want to get a WiFi antenna to go with that cable.
Fry's has started selling the Hawking line of add-on antennas.
www.outpost.com search for hawking antenna.
Just moving your little rubber duckie antenna won't be terribly helpful.
You could give up on the PCI, and get a USB-Wifi adapter which might
have a decent antenna, and can be located somewhere other than the backside
of the computer.
http://www.hyperlinktech.com has antennas. They also have a "pigtails"
listing on the cable assemblies page that might tell you what kind of
connector you have. That doesn't list your model, but there are pictures.
I don't see yours on the Linksys web site, either.
USB adapter:
http://www.linksys.com/products/pr [...] 6&prid=578
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
Reply to Anonymous
I am sorry. The card is D-Link G510 and not Linksys.
Will check out the links you provided. Thanks!
> of the computer.
> USB adapter:
Reply to Anonymous
I see some 8dbi wall mount antennas for $29.95 with the RP-SMA connector
that you need. http://www.hyperlinktech.com/web/hg2409p.php
I don't see "extension cords" with RP-SMA plug to RP-SMA jack.
Reply to Anonymous
Google /Froogle/-wifi extension cable, or
HAC7SS, or
http://www.provantage.com/scripts/cart.dll/x/0/review, or
Hawking extension cable.
Reply to Anonymous
http://www.pasternack.com/
they make custom cables and pretty much have any connector you can
think of. They are incredibly quick, and if you're anywhere near
Irvine, you can just go to their office and they'll make the cables
while you wait.
dzieciol <central@park.net> wrote in message news:<40FD8077.D98E686F@park.net>...
> HAC7SS, or
Reply to Anonymous
On Tue, 20 Jul 2004 08:48:56 -0700, NewsReader
>TIA
Southern Calif is a big place. Also, paying retail is not my idea of
economy. However, may I suggest you hook up with the Southern Calif
Free Net or various wireless groups at:
http://socalfreenet.org
http://www.socalwug.org
http://www.sdwug.org
who probably know more about the local suppliers.
You should also consult an optometrist who may help you determine that
the DWL-G510 radio is made by DLlink, not Linksys, and that it does
NOT have an externa antenna connector, making attachment of an
external antenna somewhat of a challenge.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
http://www.dlink.com/products/reso [...] 8&rid=1040
"Internal Antenna Type: Dipole with detachable reverse SMA connector"
Reply to Anonymous
On Wed, 21 Jul 2004 20:24:28 +0000 (UTC),
>http://www.dlink.com/products/resource.asp?pid=308&rid=1040
Argh. I thought the DWL-G510 was a PCMCIA card. Sorry...
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice http://www.LearnByDestroying.com
# jeffl@comix.santa-cruz.ca.us
# 831.421.6491 digital_pager jeffl@cruzio.com AE6KS
Reply to Anonymous
That's okay, the Users' Guide says that it has a diversity patch antenna.
Reply to Anonymous
- 0 +
Probably best to purchase a new antennas as well: http://www.wlanparts.com
Frank
> TIA
Reply to frank
There are 1192 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
