G
Guest
Guest
Allright so I'm dumb. Failed overclocking experiment.
I have an 700 mhz classic Athalon T-bird (the big fat ones) running on an ASUS K7V. (Award bios with a whole bunch of VIA components) I upped the cpu frequency from 100 to 130 and restarted the comp. Black screen. Nothing. Sometimes when I reboot I get two tones in succession in an endless loop.
"BoooBEEEPBoooBEEEP!"
I'm running in jumper free mode. I went to the ASUS web site and downloaded the manual to ry to find the reset jumper, but if it's there, I can't find it. I did take out the battery though and put it back in.
If someone helps me, I vow never to be this stupid again! Unless someone also tells me how to properly overclock it too after I fix it...
Please help me, I know I'm dumb, but...
