Problems with A7V333
G
Guest
Guest
Hey, just a quickie. I just bought myself Athlon XP 2100+ with 512MB DDR SDRAM (333) and Radeon 8500. The prob is, how can i know whether my memory bus is running at 333MHz?
I checked with SiSoft Sandra, it reported only 266MHz! So, anyway I can change this? Thanks a bunch!
metal143
58
Hey, You need to ugrade \ Flash your BIOS to 1.06
if you goto www.asus.com grab it from there.
The new BIOS has a fix for supporting DDR 2700 333.
good luck
