G
Guest
Guest
Hi all,
here is my problem, I got a new PC built about 2 to 3 months ago. It ran fine till 2 weeks ago. It started freezing ( and I'll get a static sound coming out of the speakers) when playing games (once in windows).I checked everything. Updated the drivers even switched video cards. No luck. Sometimes it would freez and I can not even ctrl+ald+delete. I have to press the reset button to reboot it. Then it would work fine. Other times it will freez again then I have to reboot it to make it work.
I'm assuming it it heat problem, because it happens when the weather is hot and my room is warm, but it happened yesterday and my room was freezing. (had the window open) The CPU temperature was 44 celsius(about 107F) when I do the restart.
I can not think of a logical solution for this.
Please help.
Here are the specs
Windows XP
ECS K7S5A mobo
2 sticks 256 SDRAM (same brand same speed 133)
AMD XP 1700
Visiontek Geforce 3 TI 2000 ( the one that was installed before was chaintech GF 2 TI)
Sound Blaster live value
I have 3 fans, plus the cpu, video card and the power supply fans
In another forum they suggested that I take out the SB Live Value and try the onboard sound card. No luck there.
So here is an update after I did that.
I was playing Quake III and it froze twice. No static sound this time. Just the screen freezes and silence.
latest updates.
the PC froze one more time during quake. then before I went to sleep I wanted to see if anybody replied to my problem and windows froze.(was not playing this time)
I get this error in event viewer
Event ID:9
Source atapi
category: none
The device, \Device\Ide\IdePort1, did not respond within the timeout period.
I have 2 HDs on the first IDE channel and 2CD ROMs on the second one. The burner is the master and the CDrom is the slave.
This is the same error I got when the freezing started to happen. (only if it freezes in windows, during gaming I won't see the error after restarting)
The thing is that this error went away for about 2 weeks and now it is showing up again.
Any ideas.
Last night I tried defragmenting and ran scan desk with no results. I tried to unplug the secondary CD ROM also with no luck. I'm going to try to uplug the secondary hard drive tonight and see if this help.
Please post any help you can give.
Thanks alot
Please help.
Here are the specs
Windows XP
ECS K7S5A mobo
AMD XP 1700
latest updates.
Event ID:9
Source atapi
category: none
Any ideas.
Thanks alot
