Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
As a matter of fact, if he has file allocation problems with the NTFS volume
and uses Partition Magic to change to FAT 32 he will probably trash all data
on the drive (If PM actually attempts the change.)
Please respond back to the newsgroup when your problem has been solved to
assist all on the newsgroup
"Harry Ohrn" <harry---@webtree.ca> wrote in message
news:%23ukDqVkJEHA.3184@TK2MSFTNGP10.phx.gbl...
> To run checkdisk just right click the drive icon from the My Computer
window
> and select Properties->Tools->Error checking button and check both boxes
in
> the Disk Check windows that opens. You will be prompted that the process
> will be run the next time your restart windows. So close out and Reboot.
If
> the problem persists you may well have physical damage on your drive. You
> should look at backing up your important data now.
> Trying to change from NTFS to FAT requires third party software like
> Partition Magic if you want to do it non-destructively. In any event I
don't
> think that is going to help your situation.
> Harry Ohrn - MS MVP [Shell/User]
> www.webtree.ca/windowsxp
> "dakart" <anonymous@discussions.microsoft.com> wrote in message
> news:0379211E-8B8F-411C-9514-F0EDF957DEBE@microsoft.com...
> > I tried to chkdsk by booting with xp cd. Message came up 75% completed.
> Volume appears to contain one or more unrecoverable problems. ( Is there
any
> way of changing from a NTFS back to a FAT file what's the difference?)When
I
> type in CHKDSK C:/R or /F system does not recognize Help please Any
> suggestions and thanks for any help I'v had earlier
