Archived from groups: alt.internet.wireless (More info?)
On 23 Jul 2004 08:50:42 -0700, bill.goedert@budgetcaterer.com (Bill
Goedert) wrote:
>3 pcs wireless into belkin F5D7230-4 router and router is wired to
>d-link dc200 cable modem.
>It seems that when I copy a lot of files (30+??) from one pc to
>another, I loose network connection on all 3 pcs.
If all 3 PC's lose connection, that's sufficient evidence to assign
the blame at the Belkin wireless router.
I have to point out that I purchased a similar Belkin router
F5D6231-4 that had a similar problem that could only be solved by
purchasing a different wireless router. There seems to be something
wrong with that product line, but I have no clue as to the exact
cause.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 AE6KS 831-336-2558
On Fri, 23 Jul 2004 09:18:12 -0700, Jeff Liebermann
In another thread in this group, someone posted that they were having
a similar problem with XP and "moving large files" (not a large number
of files). The workaround was to use the IP address for the shared
directories instead of the NETBIOS name. That's:
\\192.168.1.20\share_name
instead of:
\\machine_name\share_name
Might be worth a try.
You might wanna run from a DOS cmd window:
nbtstat -s (sessions running)
nbtstat -c (remote machines in the cache)
nbtstat -n (what's available)
before and after it dies to see if it really is a NETBIOS name
resolution problem. If you can't ping the other machines, it's
probably the router and not NETBIOS.
