Tom's Hardware > Forum > Systems > Dell > Latitude Problem
Latitude Problem
Forum Systems : Dell - Latitude Problem
Archived from groups: alt.sys.pc-clone.dell,comp.sys.laptops (More info?)
My latitude (PIII-650) doesn't show the picture half the time. This is from
startup so no screen shows at all, even for external monitor. Anyone have
similiar problem?
TIA,
David
Sponsored Links
"david" <davidg35@cox.net> wrote in message
news:H7C_e.83998$DW1.70700@fed1read06...
> from startup so no screen shows at all, even for external monitor. Anyone
> have similiar problem?
> TIA,
> David
>Forgot to mention that the times when the monitor DOES work is after the
>laptop has been running and is warmed up, I'll reboot and have a normal
>picture.
Thanks,
David
Reply to David
>> is from startup so no screen shows at all, even for external
>> monitor. Anyone have similiar problem?
>> TIA,
>> David
>> the laptop has been running and is warmed up, I'll reboot and have a
>> normal picture.
> Thanks,
> David
This could be a loose or burned connection on the inverter, a failing
fluorescent lamp, a spotty inverter, a simple loose power connection,
etc. You will have to open both the case and the display to track this
down. A voltmeter to measure the inverter output will be handy.
Q
Reply to Anonymous
There are 1129 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
