Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
>-----Original Message-----
>Hi, Glennda.
>If it were my system, I probably would set aside a half-
day and do an
>"in-place upgrade", as described here:
>How to Perform an In-Place Upgrade (Reinstallation) of
Windows XP
>http://support.microsoft.com/default.aspx?scid=KB;en-
us;q315341
>This will reinstall WinXP itself from scratch, but will
preserve your
>installed applications and data - and some of your
tweaks.
I will check this out.
This restores
>WinXP to its just-installed state, so as soon as Setup
finishes, make sure
>the firewall and antivirus are working, then visit
Windows Update to get the
>latest Service Pack (if it isn't already on your CD) and
later updates
>installed again. Be sure to get ALL the Critical
Updates. Read the
>instructions for the optional updates; you probably want
most of them, too.
I have all the critical ones but not all others. Does it
hurt to install all of them even though they are related
to my system?
>No, all this isn't strictly necessary. But your system
probably will run
>much better for it. Well worth a half-day investment of
your time.
>RC
>R. C. White, CPA
>San Marcos, TX
>rc@corridor.net
>Microsoft Windows MVP
appreicated, now my outlook isnt'working. I'll paste
what it said.---------------------------
Microsoft Outlook Express
The identity login could not be started. Some components
are either missing or incorrectly configured.
OK
Outlook Express
Outlook Express could not be started. It may not be
installed correctly. Make sure that your disk is not full
or that you are not out of memory. Contact Microsoft
support for further assistance. (0x8007045A)
OK
Outlook Express
Outlook Express could not be started because MSOE.DLL
could not be initialized. Outlook Express may not be
OK
>"glennda" <anonymous@discussions.microsoft.com> wrote in
message
>news:a33c01c43505$443b1d90$a001280a@phx.gbl...
>> Hi,
>> After chatting with Microsoft and getting a friend to
>> help with the system (windows xp)and trouble shooting
for
>> over 2 months, my system is finally working better, not
>> perfect but better. Atleast windows xp loads and I
have
>> access to system recovery.
>> My question is though, my system is clean and windows
xp
>> loaded.
>> So far I have the critical updates, I've installed the
>> firewall and I downloaded Mcafee.
>> What is the next step to help my system run smoothly
and
>> is there a helpful site?
>> Thank you
