OK I have the the GA-7VRXP, AMD 2100+, 2 40gig maxtor ATA133 hard drives, OCZtech DDR 366(run at 333),Geforce 4 TI 4600, and a sound blaster audigy. Put them all together.
Start winXP install.
First problem have hard time seeing drivers. Keeps comming back with nothing. Sees them but has choice for 2 different drivers. Setup files says I'm supposed to chose the "WinXP FastTrak133-Lite Controller" driver when prometed to, but gives me these to options "WinXP MFastTrak133-Lite Controller" and "WinXP SFastTrak133-Lite Controller". WTF??? Nothing I can find any were says any thing about this.
Next problem. No matter which one I choose I can only use quick format. I can't use the regular format computer crashes.
Next problem. had windows running and few different times would get a blue screen kernel stack error and computer would crash.
Next problem had winamp open went to Xbox.com to watch video. clicked on video computer froze. started to close programs and then it just rebooted. Won't go into windows now get blue screen error. Have no idea why or what happened.
Next problem think bios might need to be updated. My board came with F4 bios. I tried to flash to F6 using the procedures they had listed on gigabytes website. Computer boots back up with cmos checksum bad, gives you option to go into setup or load defualts. Then go into setup. computer won't boot if CAS is set to 2 in bios(it would before). Then if you do set everything and leave it at cas 2.5 computer gets to after it checks the raid array before it should look to CD-ROM to load winXP it freezes with a beep from PC speaker that continues forever. Only way to get past that despite several trys with different floppy and files on F6 bios, was I had to load the F4 bios back, but now computer still won't post with CAS 2 memory setting(this is DDR 366 should run at CAS 2 at 333 speed???) then now I can get to winXP load driver for raid card(still don't know which driver to choose "M" or "S") then gives error about the file. Tried different floppies just in case. nothing has helped. can not get it to load driver...
What the hell have I done wrong?? I set the array up correctly and every thing. This is not my first raid computer. Although last one had highpoint controller(abit motherboard). Getting sick of the Promise(gigabyte motherboard) crap real quick!!! Need help have no idea what to do??? HELP PLEASE HELP!!!!!!!!!!!!!!!!!!! Tell me how to set up and install computer step by step if you have to..... JUST NEED SOME HELP...ANY HELP AT ALL!!!!!!
Error RAID!!! Error RAID!!! Heads crashing down everywhere, oh the humanity!!!!
