Tom's Hardware > Forum > Games General > PC Gaming > Rome Total War problems
Forum Games General : PC Gaming - Rome Total War problems
Hey guys, I'm trying to install the v1.3 patch, but when i try to start the setup, an error box comes up saying:
"Setup has experienced an error.
Please to the following:
-Close any running programs
-empty your temporary folder
-check your Internet Connection (internet-based Setups)
Then try to run the Setup again.
Error code: -6001"
I dunno what this is about... Help!
Sponsored Links
awesome...thanks for the help guys.
Reply to chadder
You might have more success on the Rome Total War boards, or contacting the publisher's tech support.
If you problem isn't especially common, you can't expect a solution to magically appear within 24 hours! And certainly not with the smart-arse sarcastic comments.
Reply to llama_man
Quote :
ah, sorry. I didn't mean to be a dick. I'm a little frustrated. I'm trying to get the Napoleonic Total War mod working..
Reply to chadder
1.3 is old patch.
try 1.8 or 1.9
Reply to Ar_Pi
The highest patch i've seen is 1.5. I would enjoy knowing where the 1.8 and 1.9 patches are.
Reply to chadder
hmmz well i have all expansions installed and the latest is Alexander which updates the version to 1.9.
If you have only Rome Total War then install 1.5.
If its not working then try to reinstall the game.
there is also 1.6 patch but i dunno if you need it unless you want to install Alexander: 1.6 Patch
Reply to Ar_Pi
The 1.5 patch requires 1.3...hence my delimma.
Reply to chadder
i saw that other ppl also experience the same problem. it looks like Installshield error so try this FIX should solve it.
good luck
Reply to Ar_Pi
Yup, that did it! thanks alot bud!
Reply to chadder
np, have fun with this awesome game!!!
cant wait for Medevil Total War 2 8)
Reply to Ar_Pi
There are 1265 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
