Tom's Hardware > Forum > Games General > PC Gaming > Problems Installing TitanQuest
Forum Games General : PC Gaming - Problems Installing TitanQuest
Hello there,
I just bought a copy of TitanQuest and attempted to intall it on my computer. After the autrorun sequence started I recieved and error "Acces to the specified device,path, or file is denied" When I try to access the disk (DVD Version), all of the exe files give me a "This is not a valid Windows 32 operation" error. I can open the .txt files but have no access to any exe's.
I am currently running Win2k with an Athlon 850mhz cpu 768 mb ram with a Radeon 9000pro graphics card. I have two Toshiba optical drives( one is rom the other is a dvd burner) SD-R1002 and SD-R5272 which I have checked and both have the latest firmware updates.
I have the latest drivers for my graphics card as well as the latest version of Direct X.
I realize that this current machine is well below the bare minimum to run this game, but I cant even get it to load to check. This is the same machine that I played both Everquest and WOW on in the past (albeit at lower settings, but still very playable)
I did however install the game on my laptop (Acer 3003LCI) without any trouble and then when it came time to play the game, I ran into the error "Your graphics card does not support Pixel Shader 1.0) which I expected.
I did some research through the games message boards and read about problems with SecureRom. But I am not sure what that has to do with anything.
Any help will be greatly appreciated.
Thanks in advance
Millphilxx
Sponsored Links
There are 1221 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
