7VRXP + Raid = Problem?!
I've tried (many times!) to install Raid HDDs on my just bought 7VRXP but failed. Anyone has experience how to setup Raid on 7VRXP mobo?
This is my computer setup:
XP1800+
GA7VRXP
KINGMAX 256MB X 2
ATI 7500 64MB DDR
SEGATE 60G HDD X 2
LITEON DVD
RICOH CD-RW
2 answers Last reply
More about 7vrxp raid problem
  1. What is the problem you are experiencing? It's hard to give advice, if we don't know what your problems are.
    I have got the OS to install to RAID, but testing in SiSoft Sandra gives me a benchmark equivilant to a single 7200 RPM drive. Not sure why it's not running at full speed, but at least I got the OS installed on it, which is a is unfotuanitely futher than most people. I had a similar problem with Soyo Dragon Ultra Platinum, so I have to check my hardware to make sure it is all functioning correclty. It may not be the mobo, it might be a power issue, or a cable issue.
    I used the drivers from their website, but the supplied ones on the CD worked as well. I used the MB version, SF didn't work, it didn't show the drives. The ATA133 drivers showed two drives instead of just the one combined stripe. I don't have ATA133 drives, but I thought I would test it to see what would happen.
    I wish for once, I could buy a motherboard that would work properly without all these hassles.
    Best Regards,
    Lonnie Bailey
  2. <A HREF="http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=514536#514536" target="_new">http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=514536#514536</A>
    Here's another link full of 7VRXP RAID troubles.
    This little cathode light of mine, I'm gonna let it shine!
Motherboards NAS / RAID
