<b>Problem1</b>
Relevant system info:
>ASUS TUSL2-C
>2x256MB Micron CAS2
>1.2 Tually
>300 watt PS.
My PC automatically boots into the CPU frequency settings of the BIOS every time I start it. This only happens from a cold start, not when I restart the machine from within Windows. I do not have to make any changes in the BIOS when this happens. All I have to do is "exit saving (or even not saving) changes" & it boots fine into Win2K.
I was thinking maybe this is related to either the mobo battery or a BIOS setting. Since the mobo is almost brand new, I tend to dismiss the former.
Any ideas?
<b>Problem2</b>
Win2K keeps on finding new hardware when I start/restart my machine. I have no clue what it's looking for. I just did a fresh install & <b>no hardware</b> was addred/removed. In Device Manager there is a yellow exclamation mark next to:
<i>Other devices
PCI device</i>
The only cards in my machine are video (which is AGP anyway), & my Adaptec 39160 SCSI adapter. I did <b>not</b> use the native 2K drivers for the 39160 (if there is any), but the Adaptec drivers on floppy instead.
Also, I just plugged in my NIC. It gets properly detected & appears in Device Manager as well. But that damn "Found New Hardware" wizard & "Unknown device" thingy in Device Manager still persists.
Other than disabling this phantom device, how else can I stop this?
Cheers,
Ron_Jeremy
I amd innocent intel proven guilty
>ASUS TUSL2-C
>2x256MB Micron CAS2
>1.2 Tually
>300 watt PS.
Any ideas?
<b>Problem2</b>
<i>Other devices
PCI device</i>
Cheers,
Ron_Jeremy
