Ram problem help please
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I have 3 256meg Ram chips , they all work, and I have 3 slots, which all
work, tested them all.
I had 512Meg and got another chip at 256Meg, I added it ...
BUT my computer only sees 512m of Ram , reguardless of what order I put
the Ram chips in..
Why can't my computer see the extra 256m of ram??
I am using windows XP home
Please help
thank you
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
More about : ram problem
Also my mother board is:
Ga-81RXP
intel 845 agp set P4 titan series
Does it support more then 512 meg??
thank you
> the Ram chips in..
> Please help
> thank you
> Ga-81RXP
> thank you
This board supports up to 2GB of DRAM (PC 1600 or PC 2100 DDR 200/266).
There are some caveats on memory installation noted in the manual. There
are 3 slots but a maximum of 4 banks. In other words, if using 2 DDR, use
slots 1 and 2 or slots 1 and 3. (Using slots 2 and 3 with 2 DDR will not
work.)
http://www.giga-byte.com/MotherBoard/Products/Products_...
If using a combination different than 2 DDR, refer to the manual.
Sharon F
MS-MVP ~ Windows XP Shell/User
Hi
Please adjust the date on your PC - you're 2 months ahead of time.
Will Denny
MS-MVP Windows - Shell/User
"Lawrence" <lawrencesystemsnospam@isp.com> wrote in message
news:eVCNVGtQEHA.3052@TK2MSFTNGP12.phx.gbl...
| Did you happen to check your motherboard manual to see what kind (size,
| speed, amount,etc.) that your motherboard requires??
| Might try that first. If you can't find it there, check with the place
where
| you bought the computer (or motherboard). They would know better what you
| have installed.
| Then come back here and tell us what you have found there.
| "Dale Rollands" <tenchi99@pathcom.com> wrote in message
| news:40B3DB58.4080809@pathcom.com...
| > Ga-81RXP
| > thank you
all
put
| > > the Ram chips in..
| > > Please help
| > > thank you
| Outgoing mail is certified Virus Free.
| Checked by AVG anti-virus system (http://www.grisoft.com).
| Version: 6.0.690 / Virus Database: 451 - Release Date: 5/22/2004
Ever occur to you that YOU may have a server problem rather than the poster
has the wrong date set? That apparently is the case since I display the date
correctly.
"Will Denny" <willdenny@mvps.org> wrote in message
news:uXztN0sREHA.3596@tk2msftngp13.phx.gbl...
> Hi
> Will Denny
> where
> | have installed.
> | > Ga-81RXP
> | > thank you
> all
> put
> | > > the Ram chips in..
> | > > Please help
> | > > thank you
Lawrence cogitated deeply and scribbled thusly:
Please check your CALENDAR - you are posting from the end of JULY!
Thank you.
gordonATgbpcomputingDOTcoDOTuk
To email me replace the obvious!
Ask the community
