G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Hello, I hope there is a solution to this. I try to both run windows update
and manually install updates from Microsoft, but it doesn't work. On Windows
update I get the error that I might have chosen NO when asked to ack. the
license agreement - I did not..I do not even GET a dialogbox with
securitywarning.. It also suggests that the security settings might be set
to high, I have tried with both "middle low" and low. Doesn't help
I have also tried to do what is sugested in Q174360 (deleting two .dll
files) it doesn't help.
If I download a kb8xxxxx file (i.e 835732 - quite important..) and try to
run the from the HD afterwards, I get this errer message:
Can not verify integrity to the file Update.inf. Control that the
Cryptografiservice is started on this computer.
This service is started, I have also restarted it, nothing helps so far
Really hope for a suggestion about this!
Regards,
Lars H
Norway
Regards,
Lars H
Norway
