Archived from groups: alt.games.delta-force (More info?)
Hi,
Lately I got addicted to the "Joint Operations Typhoon Rising" game and
everything was working great for a while... Now the game gets stuck
constantly (I think) and there is a need to restart the machine. My
machine is working so well so I rather not to start the game many times
and to cause the system to crush.
My work is giving technical support so it might be long (:
First I don't recall any change I have made that could make this
happen, but I did restored some settings to be sure...
Anyhow my connection to the servers is good and I even get fast pings
such as 40-50ms, no problems at all till I'm in the game, ones I'm
logged in the game it will get stuck (video + sound) in the first
minute or in seconds. Nothing can be done (none of the windows hot
keys) although the keyboard is active...
I have tried different servers, different nations but with no luck
I have tried changing back the video options in the game to default,
still no luck
I have tried to uninstall it > restart > defrag > restart > install, no
luck
I have started to disable the latest applications I have installed
lately
Ok, never mind there were many thing I have tried to do before typing
this message...
My machine details are:
XP Pro (en) with SP2 updated automatically
NVIDIA 6600 GT (Latest drivers)
No windows Fire Wall, MacAfee 9 Security Center
HD 200GB STA western digital
CPU AMD 64BIT +3000
1024Mb DDR
Gigabyte NForce 4 (mother board)
I hope this is not too much I really got addicted to this game (:
I would appreciate any respond I may get from you.... Thanks
due the T and R icons in the top left corner light up ? and are you
conecting thru a router ? I had a similar problem XP PRO / Linksys router
the T andR icons would light up and the game would go into semilock i couls
still fire weapon but could not move. I unhooked from router and when the T
and R thing showed up it was only for a few seconds and the game was fine
com> wrote in message
news:1110480568.126981.4160@z14g2000cwz.googlegroups.com...
> Hi,
> still no luck
> luck
> lately
> this message...
> CPU AMD 64BIT +3000
> 1024Mb DDR
> Avi
> Avihaybi@gmail.com
